twisted60
- 245
- 43
- Jupiter, Florida
Any one tried to mount a coolant filter in their HMMWV ? I search but many find for the 5 tons filters, was wondering if it's possible and if it's worth it.
I would strongly advise you to do it on the 5 ton. My truck was incredibly crudy and I could not believe how much brown sludge came out. Even after flushing, I added a coolant filter and change it every year or so. I cut them up and still find brown sludge in the paper pleats. I use a filter with the DCA chemical impregnated into it for slow release. Check out my thread for pics on my coolant install and cut up filter. Juan's m923So Flush, Chemical or plain water ? Have not flushed my 5 ton yet, just drained and serviced with fresh Antifreeze. Guess I'll just do the drain and service on my HMMWV when it is freed from the EUC prison and in my hands.
Could you post pic of this set up as I would like to see how it is done. R&D ( Rip off & Duplicate)The coolant filter mounts on the airlift bracket in the right front corner of the engine compartment. It's not difficult to do but I'd suggest you change your fuel pump before doing it because afterwards it's a real PITA.
Put a coolant filter. Yes it is worth it. Are you going to keep the truck or NOT?Any one tried to mount a coolant filter in their HMMWV ? I search but many find for the 5 tons filters, was wondering if it's possible and if it's worth it.
That is an oil filter for common ford applications not a coolant filter! Wrong media/paper. Also wrong size threads on base!Hey fellas not a humvee owner but after working on deuces and 5 tons for years here at the house (im by no means a professional mechanic) but it doesnt matter how many times i flush these trucks it is always bad. I have run a coolant filter now for about 150 hours on my personal 925a1 and im just now starting to see the coolant stay clean. I have a filter off right now and will cut it apart if anyone is interested in what these filters can pull from the system. I run a balwin spin on base with a bypass. I have never seen it run in bypass and my first filter was over 50% full of sludge.
