Dead pilot
- 135
- 43
- Fallbrook, CA
I'm trying to clean out my system before I put my radiator, thermostat and water pump back in. I spray water in through coolant manifold and it flows and comes out a bolt hole the water pump was bolted up to. But when I spray water in the oil cooler side it just backs up and pours out. So I'm guessing I need to pull the oil cooler cover off and see if I have a blockage on the side. Am I right with thinking theres a blockage cause it should flow through out the whole system from the thermostat all the way out the other side.
Sent from my SM-N950U using Tapatalk
