Coolant temperature control(glow plug switch, PART NUMBERS
trucker 1954
TOMS RIVER NJ
Can any one help me with a part number for a Coolant temperature control(glow plug switch, 1986 6.2 has black and yellow wires with a single pole plug thanks great site
rlwm211
Guilford, NY
According to the 34P manual here it is
10045847
The Technical Manuals are available at www.jatonkam35s.com in the cucv TM section
Here is the description:
SENSOR,TEMPERATURE INCLUDES 1
ADAPTER FOR TWO TERMINAL SWITCH TO
CONNECT TO ONE TERMINAL WIRING
HARNESS
This sensor was used in the L4 and V6 engines for the Fiero amongst others. Even if you have the original sensor you can test it, either to ground, or to the two wires that connect to the sensor. Here are the resistance values and they are temperature based. I would add these RARELY go bad in the civilian sector.
From what I can tell the replacement sensor is a standard GM Coolant temperature Sensor. here is some information for testing it.
The coolant sensor (to the ECM) varies the resistance.
The Pontiac Service Manual lists:
(approximate)
F C OHMS
210 100 185
160 70 450
100 38 1800
70 20 3400
40 4 7500
20 -7 13500
0 -18 25000
-40 -40 100700
I would ask if yuou have checked the solenoid that actually operates the glowplugs?
RL
