cooling fan adjustment
ken
25
Houston Texas
Is there any way to adjust the temp that the cooling fan engages? This one comes on at 210 deg and shuts off at 200. I used my laser heat gun to double check. And make sure the temp guage was reading right. It has a 180 thermostat in it but the temp will climb untill 210 when the fan comes on. I'd like to drop it down about 20deg.
ken
25
Houston Texas
That might work. It has a hydro clutch and mabye i could use one of those switches. Thanks!
ElkyRacer
Texarkana Tx/Ar
thermostatic switch in the water crossover controls the fan. Find one that has a lower on and off temp and you are good to go. Unless its overheating as it is I wouldnt mess with it. Its at the perfect temp range for that motor.
Kyle
ken
25
Houston Texas
210 seems too hot for a 6.2. Most civi ones and the cucv's i've had have 180 thermos.
