Horst
- 12
- 8
- Munich, Germany
I am starting a new thread, it was leaking IP, but leakage is no longer my problem, it is getting a little more difficult.
The previous owner must have messed with the IP pretty bad. Obviously when he tried to remove the hydraulic head, he did not know the correct procedure and forced it out. Doing so he broke that washer sitting on top of the driving gear in the IP. That is the metal part I found when disassembling, at least part of it.
Now when I tried to replace the leaking o-rings, I also messed up the correct assembly. Now I have the HH out of the truck and need to align everything correctly to re-install. Here however comes my problem. With the broken washer, much more teeth of the gear are now uncovered and I have difficulties to align now.
Can somebody post a picture of how it looks undamaged so I can maybe reconstruct what it should look like. Attached are photos of the broken piece and how the washer now looks like with all these teethes visible.
