Correct Wire connection for additional lights?
JetbikeAnt
125
Elverson, PA
Hello All,
I plan on installing some off-road lights. What wire number should I pull Positive from? 16A? 2A? The Battery Shunt? Thanks in advance!
TOBASH
3,397
Brooklyn, NY
Dashboard side plug pin "B" on PCB/EESS IIRC
Refer to post # 51 in my thread, in order to thieve 24 volt power that should turn off when you switch the ignition off.
Use of a relay system is strongly suggested. Use of low amperage LED lights is highly suggested.
I accept no responsibility for damage to your vehicle or you or persons or properties.
