Could this be the ignition (column) switch?
edpdx
75
Oregon
I replaced the ignition key cylinder last week with a unit from NAPA. Today while I was out I went to start my Blazer and I hear the "No start" >clack< of the starter relay. I, in shock and fear, accidentally turn the key all the way back to the ACC position and try again. It fired right up. I made the bold/idiotic decision to make one more stop- ok, 2 more stops on my way home. I repeat the same scene. On the last start, I turned my key to ACC first- started right up.
Does the rod that the key throws to the ignition switch get bent over time? I replaced the ignition switch last summer with a new Echlin part and it worked fine... until today. If not the rod then I was thinking the column mounted switch is slipping. Does this sound right?
Warthog
232
OKC, OK
Sounds like the switch at the bottom of the column is out of adjustment by a hair. It wasn't an issue when the ACC position wasn't used but now that you are using the ACC for your radio, it MAY have moved the switch slightly.
Cheap to check.
I don't recall if it is in the TM or not.
