panzerjunky
- 1
- 0
- san diego ca
Hey good evening
I have a couple very small leaks just wondering what they might be
No# 1 right behind the bell housing but before the trany (bottom of truck) there is a small rectangular plate held on by 6 bolts 2 are missing never leaked before ran a short mile and a half tonight to pick up some construction debris and there was oil on the ground below the plate and around the hole where the fording drain plug goes. If I pull that plate to rtv it then replace the 2 missing bolts I wont get drenched with oil will I?
No #2 on the stearing gear again looking up from under the truck there is a what looks to be about a 7/8 bolt with a another bolt in it with a screw slot on the inboard side of the stearing gear what is this and it has a tiny bit of oil leaking around it .
Jerry
Jerry
