- 1,665
- 2,129
- 113
- Rosamond, CA
I wonder if they had to "customize" that headset for Herman.Time to mix those radios and military rigs this weekend. Get out and on the air.
View attachment 871248View attachment 871249View attachment 871250
5-9 DM05....WA6VVC & WA6CAM, CAMO
None of my radjos go down that low....20m: 14.078. 40m: 7.078. 80m: 3.578. Those are the most common.
Class | Examination Difficulty | Privileges |
Technician | Easy. The course material covers radio basics and safety material. Very simple calculations. | Line of sight communications using relatively inexpensive radios. Good for local communications. Entry-level equipment is approximately $200 to $300, although you can spend more. See here for a discussion of how much it costs to become a Technician operator. |
General | Somewhat harder. More detailed radio material, including some straightforward calculations. | Worldwide and local communications. Requires more significant equipment. Entry level equipment starts around $1000. Again, you can spend more! See here for a discussion of how much it costs to become a General operator. |
Amateur Extra | Quite difficult—not at an engineering level, but close. | Same as General, except on additional frequencies. Also permitted to administer examinations. |
