I have a couple of questions to ask the experts here. I have a winch that I thought was from and LMTV crane and was corrected, it is a Grove Crane, probably an M977 that was on the early HEMTT's. To me, it appears they changed the outriggers, but both the LMTV and HEMTT had a nearly identical crane and winch.
From what I read, the Grove winch is 5,000# capacity. Sure that is light when on a HEMTT, but will work fine on a smaller crane on my deuce....if I can make it work correctly. Some things about it are just not obvious to me, or someone wanting to put one into service. I read that these were special for the military, so there are no Grone TM's that can be gotten. If you have the military, and it goes into more detail than the operation, into the schematics....I would be extremely happy to have a link.
Both trucks have a 3,000 lb max, 2,500# operating hydraulic system. That would be a pressure compensated, piston (or vane) type pump. I read the HEMTT also has a 195# system (control) but I don't know about LMTV's. Anyway....I'm trying to figure the control of this winch out, so I can use it.
I took the winch and brake unit apart to understand it's functions, not knowing what to expect. While in there I replaced all the o-rings. I have a thread on that but I need some help understanding it's operation. The wet clutch has ports into a piston area on the brake unit and into the frictions. Springs hold the frictions and steels tight. One port makes the pressure on the clutches tighter, one acts against the springs on the piston, releasing it and one is into the wet clutch pack. Pressure in that area would also seem to release the wet clutch.
There is a one way clutch between the main shaft, powered by the hydraulic motor. In forward (winch in) it locks, preventing the release of cable and reverse (winch out), the brake must release and the motor turn the opposite direction. Thus the winch is really only braking in the winch-in or stopped, keeping it from unspooling with a load and the hydraulic motor can be winch-in without any actuation of the brake at all. But to winch out, the brake must be released.
Please help confirm the lines that operate the brake and which motor, that on mine has (Parker), but no numbers I can find. I think it is a pilot operated check on the motor, where it locks one port until pilot pressure is applied. Logic would dictate that it releases (applies pilot pressure) when the valve shifts to winch out direction.
There is a 1/1 ratio and 10/1 ratio pilot line model of the control I believe I have. I can't find any numbers, just the name Parker.
Any information that you can give me to rig this thing up on a lighter crane would be appreciated.
I do have a pressure compensated piston pump, so have the right pumping system for it.
