Crank front oil seal
chemicaljohn
Laporte, IN
Hey guys, I'm looking at having to change the front oil seal on my Duece, the one pressed in to the timing cover. It pisses everywhere and gets a little worse each time I drive. Any tips on doing this? The TM makes it look pretty straight forward. Also the P/N I have is 10912514... Anyone know of an alternate # at a parts store. So far Saturn Surplus is the only place i've seen it.
M543A2
11
Warsaw, Indiana
My best way to remove the seal from the cover recess is to use a small drill (watch the shavings - grease on the end of the drill will catch them if you are careful) and put three equally spaced holes in the steel face of the seal. These holes need to be the right size to accept three large sheet metal screws. With the screws in the seal, use a notched pry bar to alternately and carefully pry out under the head of each screw a bit at a time to pull the seal out of the cover. I looked at a seal, but it had only ordnance numbers on it. If you take it and your front damper to a store like NAPA, they can measure the OD of the seal and the OD of the damper nose that goes into the seal and give you the right seal. If your damper's nose has a groove cut in it where the seal sets, buy a Speedi-Sleeve to repair it. NAPA has then also.
Regards Marti
