Does anyone have a photo showing the location of the crank position sensor on a 1151 6.5L Turbo?
When I turn the engine on the trans light remains on, so want to check that sensor connection since the TCM doesn't see the engine running. Did a bunch of power washing off a decade of dirt off so figure I might have messed with the connector to the harness as everything worked before the wash down.
Thank you
Thank you
