CTIS deflates single tire when M923A2 shut off
Alexsha
Cache Valley, UT
So today I replaced 2 of the 3 solenoids in my CTIS and magically the system came to life. After letting it run for a while then shutting the truck off, the front axle quick release was blowing air and airing down the driver side tire. It ended up at about 20 psi or so, at which point the quick release stopped blowing air. I've been going through the Dana/Spicer troubleshooting guide and the -23 TMs to make a checklist of what to look into, but Im hoping someone else has encountered this and would share their findings.
I've tightened the CTIS fittings and there seem to be no major leaks. I need to get out the soap and water to do a more thorough check though.
Things to check:
Quick release fittings and seals
Dirt/gunk in quick release that might have left it open
CTIS wheel filter
CTIS wheel valve fittings and seals
tl;dr: what is the most likely culprit of a single wheel deflating out via the CTIS?
Suprman
707
Stratford/Connecticut
If air is blowing out quick release valves with the truck off chances are you have a bad wheel valve. Easy fix. They corrode inside and the flapper won't seal right. Sometimes you can take it apart and clean it up. Take off the hose going to the hub. No air should be coming out. You can take a plastic bag and rubber band scrunch the bag over the valve and rubber band it. If air is leaking out the bag will expand.
Alexsha
Cache Valley, UT
Well I took the wheel valve apart. It was nasty in there. I cleaned out the gunk and put it all back together. No change. I did notice that it basically deflates whenever the CTIS is not inflating. So the ctis is cycli g on and off a lot. When I shut the truck down I was able to remove the little cap screw on the valve and use a thin rod to push the valve shut. Would it be worth it to get a rebuild kit (new diaphragm, bolts, etc.) or am I looking at a whole new valve?
Suprman
707
Placement does not matter they are different. You can look and tell the 2 styles apart. One is older. Most A2 trucks have the older style I have seen a few with the newer style. The new style is the same as the ones on the LMTV trucks.
charlesrg
95
Nj
I wish this thread was closed with a confirmation that the valve replacement resolved or not. Having the same problem here.
charlesrg
95
Nj
Thanks @Suprman , tried just like you suggested, no air leak on the wheel diaphragm.
I also tried filling up to 70PSI to see if it would open, no leak.
When I turn the truck 2 tires keep inflating to 70psi (pressure set on the CTIS controller) and then back down.
The CTIS says it can't close the shut off valve.
The air is escaping through the air valve:
I'm still trying to find where the problem is.
