- 464
- 267
- 63
- Seville, OH
Thanks to @NV555 for a new controller harness, @Steinmeister for a 60psi controller, @FMTV-Parts for the working PCU.
All in all this was worth the diagnostics!
1) The PCU had a sticking valve. Seals were dry rotted so removal in order to clean the valve was ok, but no seals available.
2. The harness from the controller had a broken wire. Wiggling the cable at the plug made lights flash on the controller.
3. The controller itself has some issues. No flashing lights, but when switched to Sand it doesn't deflate. The M1083? 60psi controller was an upgrade plus fixed the problem.
Now, the last problem is the left rear wheel... it doesn't inflate, so I'm guessing a stuck wheel valve?
