KN6KXR
- 541
- 93
- Felton, CA
So I'm after my M936A2 CTIS system. Trying to get it operational. It fails and flattens the tires. I have a major leak or error someplace. The control solenoids are good, I've refitted the updated transducer, works as it should. Now I'm updating all the wheel QRV's and lines to the new style. As I'm doing this I'm trying to come up with ideas to isolate parts and I thought of this:
-If one were to install schraeder valves in the lines from the QRV's to the tire then will it still do the check and pass as if it were normal? This assumes the tires are only in inflation check, below the target pressure, and would not be able to deflate. Still work?
-If one were to install a tank valve with schraeder and cap in the end of the hose to the QRV (essentially dead ending it) would it still pass the same inflation start up check?
I'm trying to come up with something easier to detect something like a hub leak. Easier than the process outlined in the TM. Something that can be done from the outside of the rim without finding the right plugs for the lines and adapters and whatnot. Any advice or experience appreciated!
