CTIS troubleshooting
shadowdd
College Station, TX
I have had a CTIS system that has worked flawlessly for 5+ years. Now the controller flashes like normal but I NEVER hear the relay at the passenger footwell check the air. Is there a voltage check I can do at the relay or is the someone in central Texas that has a relay I can buy / borrow to test the system? I checked underneath and did not see any loose wiring or noticeable bad connections. It’s nice to have an operational system. Thanks in advance.
Andyrv6av8r
454
Spartanburg,SC
Jump out the pressure switch on your wet tank first.
