CTIS wheel valve do not close (solved)
Plasa
318
Italy
If you are changing the tire and the CTIS wheel walve will not close after pressure check or inflating, check the banjo screw if there is some dirt. Happen to me yesterday. If the pressure don't fall under 20 psi between wheel valve and banjo screw the membrane do not close...
Christian
