CTIS works somewhat for the 1st time
Reworked LMTV
Expedition Campers Limited, LLC
1,174
TN
I bypassed the pressure switch at the tank, and new sounds that I had never heard before occurred. Yay! It looked like only the front tires responded to the Sand command. Maybe a bad valve in the rear? I have heard of people turning up the pressure at the regulator to trigger the switch. Is this the regulator at the tank, or is there on at the compressor?
ramdough
1,729
Austin, Texas
I have heard that because the front has more weight on it, you see the pressure drop more and deflation is faster.
Sent from my iPad using Tapatalk
Ronmar
7,451
Port angeles wa
You set the air pressure in the system using the adjustment on the governor on top of the air compressor. You need to connect a pressure gauge onto the wet tank to do this properly though.
the thing that looks like a regulator on the wet tank is called a protection valve and shuts off air to CTIS and cab suspension when the wet tank pressure drops to 85 PSI to save air for the brake system...
