Ctis
plainside
MN
HI All again,
On my M925A2 I was driving off road like I always do in HWY mode, (cuz I do not want to mess with the CTIS Settings). And the top 4 lights started flashing while driving, shut the truck down and looked for an air leak, because I assume that is what the 4 flashing lights are for. Found or heard nothing, restarted the truck and back to normal. whats the deal?>
hklvette
Christiansburg, VA
The CTIS still functions even if you don't change the setting, as it regularly checks the tire pressures. 4 lights usually means one of your tires is low on air.
plainside
MN
OK, so maybe I can play with the ctis settings to sand or so forth. But after I shut it down and restarted the 4 lights did not come back on, just never had that before. THe HWY one flashes every now and again but then goes to steady on.
MtnSnow
14
NSL, UT
4 Flashing Lights or CHECK TIRES Flashing (Codes 44, 45)
Type: Tire Leak (Imbalance)
Note: RUN FLAT overrides this fault.
Air Pressure Check
Note that the Central Tire Inflation System is not continuously
pressurized; pressure checks occur on a periodic basis.
During tire pressure checks, the system delivers compressed
air to each channel for approximately two seconds while
monitoring the pressure in that channel.
Code Description
An “Imbalance” code indicates that either the tire pressure on
one tire or wheel end was read lower than the other tires, or
there is an air leak someplace in the system.
Low tire pressure can be caused by a damaged tire, plugged
wheel valve filter or leaking air lines. An air leak can be located
either before or after the wheel valve.
Note: When using a diagnostic tool to inflate or inflate-hold a
channel with one low tire, air may be heard leaking out
or the Quick Release Valves (QRV) by the higher pressure
tires. This is normal and should stop once the low
tire is inflated to the pressure of the other tires.
The components located before the wheel valve that may
cause a “Tire Leak (Imbalance)” code include:
• Leaking wheel air seals
• Leaking control lines
• Restricted QRV exhaust port
Components located after the wheel valve that may cause an
imbalance include:
• Damaged tire
• Rim leaks
• Clogged or restricted Wheel Valve filter or valve stem
• Leaking air lines
• Wheel valve damage
To correctly diagnose the faulty component, connect the Diagnostic
Tool (see "Diagnostics" for test equipment and descriptions)
and follow the procedure in the Tire Leak (Imbalance)
troubleshooting tree.
See “Troubleshooting Tips” for general guidelines on system
diagnostics.
System Mode Condition Possible Causes (listed in order of likely occurrence)
Channel only
checks pressures.
Tire pressure lower on one
tire than others.
• Minor tire leakage at startup (leaked overnight)
• Severe tire damage or leaks
• Contaminated wheel valve filters
• Restricted tires valve stem
• Leaking lines
• Leaking seals
• Leaking wheel valve
• Crimped or restricted control lines
plainside
MN
Thanks, checked all the Tire pressures when cold and vehicle not started in two days and they were all 62-63 PSI.
Thanks !
