cucv 1008 relay
tweeder199601
dover, pa
Did the bypass for the resistor to the relay, put new glow plugs in, new relay in, went to start it, and its not cycling on and off, also got 12 volts to each post, except the bottom post on relay, any ideas?
1,171
What glowplugs and relay did you install?
1,171
Sounds like your controller may be bad or your temp sensor.
1,171
Did your system work before you resupplied the GP relay with 12volts?
1,171
Yes and I posted it in one of the 2 other threads you have started on this subject lately.
You need to continue one thread to diagnose and repair something.
Crossposting is against the rules for obvious reasons.
1,171
Also, there is a complete step by step diagnostic section in the -20TM, in the troubleshooting section.
Very easy to follow.
Have you removed and visually inspected your controller card? You asked where to get one yesterday.
1,171
It was a BWD number, wasn't it?
Borg Warner
cucvrus
9,888
Jonestown Pennsylvania
Bring that thing up here to Jonestown PA and we will fix that thing. I just had a fellow bring his CUCV M1009 truck here from NJ yesterday and we fixed up his CUCV starting glow plug system. Before he unloaded it off the trailer it was on. You are only an hour away. Get on 83 N - 81 N exit 90.
