just throw that sucker away and hook your glow plug relay up to the 12 volts right there next to it on the firewall. .and say GOODBYE to fried glow plugsAny one "on line" well verse with the CUCV starting system, that I can talk to about the CUCV 24v. resistor?
You are so right.just throw that sucker away and hook your glow plug relay up to the 12 volts right there next to it on the firewall. .and say GOODBYE to fried glow plugs
The reason for use of 24 volt GP is to reduce the draw on the batteries. But since half the energy is wasted in the ballast resistor, there is only the balance of each battery during starting. Since each battery is independently charged by each alternator, if you go with the 12 volt tap for the relay, you can offset this imbalance by using a larger front battery.
With equal sized batteries, tapping off the 12 volt side for the glow plugs will result in voltage depression in the front battery for the starter. This may affect extreme cold weather starting.
Yes, the ballast resistor has problems in cascade failure of glow plugs.
Didn't know they were 24volt...you say the origional humvee w/ same 6.2 where 24 volt????The best solution is to use 24 volt glow plugs and bypass the ballast resistor. That and better glow plug design that don't expand when they fry. I think the older HMMWV plugs should work.
I know the Beru/Bosch glow plugs are like this, if they have an over-current issue, they fail open before they melt themselves into a blob.
The problem with this is that there is a voltage sense line to the controller card and constant 24V will fry it and other components on the card over time. If you could figure out how to install a resistor to drop the 24V to 12V only for that sense wire, then you could follow your plan.The best solution is to use 24 volt glow plugs and bypass the ballast resistor. That and better glow plug design that don't expand when they fry. I think the older HMMWV plugs should work.
Resistors only drop voltage when there is current according to Ohm's Law (V = I * R). The controller has limited current draw, this wire is at 24 volts whenever there is no glow plug activity.The problem with this is that there is a voltage sense line to the controller card and constant 24V will fry it and other components on the card over time. If you could figure out how to install a resistor to drop the 24V to 12V only for that sense wire, then you could follow your plan.
Later,
Joe
