RickTheEngineer
- 5
- 16
- Mount Laurel NJ
Howdy! Another day, another thing worth fixin' right? Alright so I had something strange happen to my truck today. I was at a red light, foot on the brake pedal, and it was holding pressure just fine, then suddenly fell like an inch (while maintaining same pressure on pedal) then held for a while, then fell all the way. Now here is the thing, I have replaced several master cylinders in my time, but none of them gave out like this. It just kind of falls in strange increments instead of slowly sinks. This isn't the hydroboost is it? Also, other details were 3 months ago I swapped over to DOT 5 because when I bought it, it seemed to have DOT 3. I flushed out the brakes as best I could with several bottles of the stuff. The fluid was nice and purple from the lines and in the cylinder. Today when I opened the reservoir, I saw it was all brown, with a thin film of clear liquid on the top. Also no leaks anywhere to be seen. Bled the brakes, same story. Do you all think that its time for a new master cylinder? If so, would you trust a NOS part, or are the seals gonna be worn out and dry (gonna buy a K30 Master)? Thanks!
EDIT - also I presume the M1008 and M1009 have the same master part #?
