CUCV cuts off
Amnon
Raleigh, NC
For the last few times, when I start the CUCV after it sits for a few weeks (it
is not a daily driver), it will start right up, but after about 30 seconds, the
rpm will go up a little and then the engine will cut off. Restarting it will
take maybe 5 to 10 seconds of starter work, and then it will run fine. If I
start it weekly, there is no problem.
Any ideas?
Amnon
m38inmaine
53
Maine USA
Sounds like an airleak as said before or you may have the old style(fuel)lift pump. The newer style has a check valve that won't allow fuel to drain back. Same for the older IP's, there is an article in the TM section that explains it.
