Cucv door markings
MSgt USMC (Ret)
Concord, NC
Mine looks like it was a chaplans unit and had crosses on the doors.
That's a Center of Balance or C/B marking. It was required for movement by air. That marking would be about the center of balance for a CUCV. Normally units would use masking tape to mark the "CB" as it would likely move a few inches from embarkation to retrograde depending on the cargo load
Chaplains attached to USMC units rarely if ever had a dedicated vehicle. If they needed to get around the CO's vehicle would commonly be used.
1 Patriot-of-many
87
Zimmerman MN
Mario,
Most of the ones I have seen are " FOR OFFICIAL USE ONLY" also for mine it was vinyl lettering rather than a painted stencil.
-Dale
Oh yeah I doctored mine some.
HAHA I love that. What color paint or vinyl lettering would be appropriate for woodland camo?
dependable
188
Tisbury, Massachusetts
Uncovered this on my M1031. The plate shows door was originally in a m1008. High mortality rate on 1031 doors? Like they did not chock it when running PTO.
I believe IFOR was the 'stabilization force' in Bosnia.
M813rc
3,679
Near Austin, Texas
Per the manual- black on green/brown areas, green on black areas.
Cheers
PS added pics for example. Marine CUCV's often had the USMC###### on the door just above the crease line. Also, the Marines usually write the tire pressure as ##PSI, though they do use TP## also.
Haweneyu
Laurelville, Ohio
My 86 CUCV M1009 has the word "STAMPER" on the drivers door just below the window. Not sure what it means though.
A while back at Mechanicsburg I was doing a pick-up in the yard and had seen a sand colored blazer that had a VERY well done skull and crossbones on the doors.......I'd have bought it just for that reason!...cooooolll !! :-D
Legnasol
Cuba
I am trying to gather pictures of door markings (and any others) on Cucvs so i can figure out what i want to put on mine. It doesn't run so I am getting antsy and have stencils and spray paint, so I need to do something right? (and i can't fix it yet Since the IRS likes to take its time with my money)
These pics are of my cucv they tried to cover with spray paint but you can see markings if you zoom in
