EO2NMCB
- 23
- 18
- DeSoto, MO
Bought the m1009 from gl and have been unable to get it started. I installed a manual GP switch, have power at the plugs, but didn't have time to ohmn them out. Have read the troubleshooting in the TM 20 and 34 and did a search here on SS, not sure what I'm missing. Lift pump is good and fuel at the filter, the top of the IP at the shut off sol has fuel also. I pulled a line of the injector and it was wet, but didn't seem like a lot of fuel when cranking. I did also try a very small shot of starting fluid without using the glow plugs and it made a sound like spark knock on a gas motor, but would not start. How do you check the IP without doing the bench checks in the tm-34 or tell if its bad? Please help before its BFH time. It maybe a week or two before I can do more checks, since I'm a OTR driver.
thanks to all
thanks to all
