CUCV Front proportioning valve
usmc80
Gettysburg, PA
Does anyone know where I can find a front proportioning valve or have any idea what other chevy's models are compatible at the junk yard?
kingchr
Prospect/Oregon
Other rigs to get one from
Yep its to balance the front and rear breaking force.
I could be wrong, its happened before, but I think almost any 80s square body truck will have this valve for you with the correct fittings.
Take it easy, and good luck,
Christopher
usmc80
Gettysburg, PA
Christopher
Thanks I am slowing realizing the same thing. It appears that they used the same valve for 1/2 ton - 1 ton trucks. Hopefully it works. worst case I wasted $10 at the junk yard
Castle Bravo
Hundredaire Socialite
220
Arizona
According to the -34P TM, the blazers and pickups use different valves.
GM Part # 25515635 for the M1009 and GM Part # 1257203 for the pickups.
21 PAOZZ 11862 25515635 VALVE,SAFETY RELIEF 1 UOC:209
21 PAOZZ 11862 1257203 VALVE,BRAKE 1 UOC:194,208,210,230,231,252,254,256
21 PAOZZ 11862 1257087 VALVE ASSEMBLY 1 UOC:254,256
donalloy1
Martinez Ca
:-D Thanks for digging that up Castle Bravo! Will add to Laundry List...
usmc80
Gettysburg, PA
Thanks for looking that up.
