CUCV Glow Plug Controller - diode part number
firefox
General
51
Berkeley CA
Hi All,
Does anyone know the correct part number for the clamping diode that is connected to the relay feed?
Bruce
firefox
General
51
Berkeley CA
The reason I need the part specs is because someone removed the original and put a small signal diode in its place with obvious results...burned trace grrr.
Bruce
firefox
General
51
Berkeley CA
My camera is on the fritz. groan, but it is easy to locate the diode. Look for the single tab type transistor on the board. The diode goes from the output of that transistor to the card edge.
It is right in the corner of the card next to the card edge connector. If you don't spot it, let me know and I'll draw a picture for you and post it.
Thank you very much,
Bruce
firefox
General
51
Berkeley CA
Position of diode on board.
Hold the board with the card edge fingers pointed up and you are facing the component side.
Diode is the top right component on the board.
The center leg of the tab transistor points to the diode on its right.
I hope this helps.
Bruce
cagosti
mich
diode
that type of diode would be a 1000 PIV 1 to 3 amp silicon diode
radio shack should have it.
charles
Portage Mi
firefox
General
51
Berkeley CA
That's fantastic Charles! Thank you very much!
Bruce
