- 115
- 120
- 43
- Los Angeles/CA
Hopefully this is a quick question for the CUCV electrical experts.
I have a 240 mA current draw on the 12V battery connection with the key off. With the 30A headlight fuse removed that is reduced to 35 mA, which is about what I would expect for a CUCV. I have reviewed the TMs and both of Warthog's excellent posts on the headlight system and fuse panel:
The full 240 mA load remains with the 30A headlight fuse in place and the 15A horn (#11) and 20A courtesy lamp (#16) fused removed. See Warthog's diagram attached for number references. Physically unplugging the headlight switch with the 30A fuse in place also still has the full 240 mA load. Setting the blackout switch to the center position ("all off") reduces the load to 35 mA, just like pulling the headlight fuse
This is my understanding of the headlight electrical circuit from reviewing the TM:
Does anyone have suggestions on what I can try next? I am not sure how to narrow down the problem from here.
CUCV Headlight Circuit Explained
The headlight circuit causes many problems for most CUCV users. The GM design could use some improvements as the Headlight Fuse actually provides power for multiple circuits. We will cover those shortly. Let's look at the headlights them self first. Whenever troubleshooting any electrical...
www.steelsoldiers.com
CUCV Fuse Box Layout
There are some errors in the TM diagram for the CUCV fusebox. I will attempt to point them out as I find them Here is a "clean" fuse box with all the proper fuses and labels ITEM 2 - Hazard Flasher 3 - not used except for the M1010. The M1010 uses it for Ambulance Accessories 4 - no...
- 12v power is from the battery is supplied by 8 RED-2A to ENG WRG HARNESS BLOCK. Disconnecting this at the battery eliminates the current draw (obviously)
- Power is fed from engine bay 12v block to the fuse panel in the dash by 3 RED-2G. Disconnecting this wire at the engine bay 12v block also eliminates the draw (again by stopping all 12V power to the fuse panel)
- Internal connections inside the fuse block jump power from the 30A headlight fuse (#7) to the 15A horn (#11) and 20A courtesy lamp (#16) fuses. Disconnecting either of these downstream fuses has no effect, indicating the problem circuit is fed directly by the #7 headlight fuse
- Turning the blackout light switch to "all off" or pulling the 30A #7 fuse eliminates the draw, reducing key-off battery load back down to 35 mA
