- 14,718
- 5,162
- 113
- Buchanan, GA
FAQ
http://www.steelsoldiers.com/showthread.php?20600-FAQ-Thread-for-CUCV-s
STARTER
CUCV Stock Starter Circuit
http://www.steelsoldiers.com/showthread.php?129483-CUCV-Starter-Circuit
CUCV Doghead Starter Relay Modification
http://www.steelsoldiers.com/showthread.php?60960-doghead-starter-relay-modifcation
http://www.steelsoldiers.com/showthread.php?61184-Doghead-relay-mod-on-my-M1028
Doghead Starter Relay mod poll
http://www.steelsoldiers.com/showthread.php?70846-Poll-Who-has-done-the-Doghead-Relay-Conversion
Starter Brackets, Bolts and other Info.
http://www.steelsoldiers.com/showthread.php?15551-Starter-bracket-bolt-size
Burned Fusible Links after Starter Run on Explained and Illustrated
http://www.steelsoldiers.com/showth...fter-Starter-Run-on-Explained-and-Illustrated
Fusible Links 101
http://www.steelsoldiers.com/showthread.php?122571-Fusible-Links-101
Starter Rebuild Kits
http://www.steelsoldiers.com/showthread.php?136886-Alternator-and-starter-parts-amp-repair-kits
Old Style Direct Drive MT-27 Starter Rebuild
http://www.steelsoldiers.com/showthread.php?96119-Epic-27MT-Rebuild-quest
Another cause for Starter run-on
http://www.steelsoldiers.com/showthread.php?122850-Broken-starter-nose-conep
ALTERNATOR
GEN1 and GEN2 Exciter circuit troubleshooting
http://www.steelsoldiers.com/showthread.php?121589-CUCV-GEN1-and-GEN2-Exciter-troubleshooting
CUCV Isolated Ground Theory of Operation
http://www.steelsoldiers.com/showth...ternator-Isolated-Ground-Therory-of-Operation
CUCV Alternator-symptoms-diagnosis-and-fix
http://www.steelsoldiers.com/showthread.php?54292-CUCV-alternator-symptoms-diagnosis-and-fix
CUCV Alternator Rebuild - illustrated
http://www.steelsoldiers.com/showthread.php?146703-CUCV-Alternator-Rebuild
http://www.steelsoldiers.com/showthread.php?60299-CUCV-Alternator-Rebuild-Question
Convert a Civvy Alternator to an Isolated Ground if you busted your case
http://www.steelsoldiers.com/showthread.php?56186-Isolated-Ground-Alternator
Alternator Rebuild Kits
GLOW PLUG SYSTEM
GP Module Operation
http://www.steelsoldiers.com/showthread.php?62477-GP-Module-Theory-of-Operation
GP Temperature Sensor
http://www.steelsoldiers.com/showthread.php?116079-Temp-Sensor
GP Relay Repair
http://www.steelsoldiers.com/showthread.php?97492-Glow-Plug-Relay-Repair
GP Resistor Bank Bypass
http://www.steelsoldiers.com/showthread.php?121398-GP-Resistor-Bank-Bypass
http://www.steelsoldiers.com/showthread.php?134320-A-muddy-resistor-bypass-overkill-is-a-GOOD-thing
Manual Glow Plug Switch
http://www.steelsoldiers.com/showthread.php?144924-How-To-Manual-Glow-Plug-Switch
HEADLIGHTS
CUCV Headlight Circuit
http://www.steelsoldiers.com/showthread.php?87544-CUCV-Headlight-Circuit
CUCV Melting Headlight Fuse and Horn Circuit fix
http://www.steelsoldiers.com/showthread.php?104746-Why-is-my-headlight-fuse-melting
LMC Headlight Wiring Harness upgrade
http://www.steelsoldiers.com/showthread.php?124720-LMC-Truck-Head-light-circuit-mod
HORN
Horn Blowing all the Time
http://www.steelsoldiers.com/showthread.php?90190-CUCV-Horn-relay
Horn Contact Replacement
http://www.steelsoldiers.com/showthread.php?126973-Horn-Contact-Replacement
ELECTRICAL
Fusible Links 101
Soldering wires
http://www.steelsoldiers.com/showthread.php?150320-Electrical-soldering-connections-basics
CUCV Fuse Box Layout
http://www.steelsoldiers.com/showthread.php?132309-CUCV-Fuse-Box-Layout
CUCV Electrical Ground Locations
http://www.steelsoldiers.com/showthread.php?120289-CUCV-Electrical-Ground-Locations
CUCV Switches Diodes Relays
http://www.steelsoldiers.com/showthread.php?50551-CUCV-Switches-Diodes-Relays
Battery Wiring Maintenance
http://www.steelsoldiers.com/showthread.php?72880-Battery-Wiring-Maintenance
CUCV Color Wiring Diagrams
http://www.steelsoldiers.com/showthread.php?75505-CUCV-Wiring-Diagram-color-(except-M1010)
CUCV M1010 Color Wiring Diagrams
http://www.steelsoldiers.com/showthread.php?158356-Colored-Wiring-Diagrams-(M1010)
Blower Motor
http://www.steelsoldiers.com/showthread.php?130128-Blower-motor-out
Rosscommon 24v to 12v conversion
http://www.steelsoldiers.com/showthread.php?145322-CUCV-Rosscommon-24v-to-12v-Conversion
Turn SIgnal/Steering Column Troubleshooting
https://steelsoldiers.com/threads/turn-signals-not-working-steering-column-wiring.196603
INSTRUMENT CLUSTER
CUCV Instrument Cluster Cleanup
http://www.steelsoldiers.com/showthread.php?52821-Instrument-Cluster-Cleanup
CUCV Instrument Cluster Repair
http://www.steelsoldiers.com/showthread.php?43351-CUCV-Instrument-Cluster-Repair
CUCV Instrument Cluster Decoded
http://www.steelsoldiers.com/showthread.php?46054-CUCV-Instrument-Cluster-Decoded
HEATING/COOLING
CUCV Heater Core Replacement
http://www.steelsoldiers.com/showth...ent-Heater-Cores-No-or-Low-Heat-Output-Reason
Current Flowing thru heater core and corroding system
http://www.steelsoldiers.com/showth...-resulting-in-leaking-of-heater-core-into-cab
OIL COOLER HOSE REPLACEMENT
Custom fit oil cooler hoses - Updated 8-20-2017
https://www.steelsoldiers.com/showthread.php?96746-Custom-Oil-Cooler-lines-pics-info
FUEL SYSTEM
Spin On Fuel Filter Upgrade - Post #28 has a filter chart
http://www.steelsoldiers.com/showthread.php?36435-My-CUCV-spin-on-fuel-filter-mod
TRANSMISSION
Throttle Vacuum Valve Adjustment for late shifting
http://www.steelsoldiers.com/showthread.php?50568-CUCV-Throttle-Vacuum-Valve-Adjustment
TH400 Rebuilding Tips
http://www.steelsoldiers.com/showthread.php?149390-TH400-Rebuild-tips
Transmission swap with a 4L80e
http://www.steelsoldiers.com/showthread.php?64004-The-mythical-CUCV-4L80E-swap
700r4 swap
MISC
Insurance
http://www.steelsoldiers.com/showthread.php?121234-Insurance
Parts supplier CUCV Electric, Inc. Explained
http://www.steelsoldiers.com/showthread.php?103428-CUCV-Electric-Explained
M031 Generator Control Fix
http://www.steelsoldiers.com/showth...stem-using-b4thundr-Woodward-Apecs-controller
M1009 Tie Rods and Tie Rod Ends
http://www.steelsoldiers.com/showthread.php?125140-M1009-Tie-Rod-End-Replacement-Project
CUCV Torque Specs Cheat Sheet
http://www.steelsoldiers.com/showth...pec-Cheat-Sheat-M1008-M1009-M1010-M1028-M1031
M1010 Threads
M1010 Belt Numbers
http://www.steelsoldiers.com/showthread.php?104174-CUCV-fan-belts-for-m1010
M1010 Duvac Removal
http://www.steelsoldiers.com/showthread.php?37909-M1010-No-more-DUVAC!!
http://www.steelsoldiers.com/showth...ower-design-for-M1010-house-bank-and-no-DUVAC
*Thanks to cucvnut for helping combine all these threads/previous stickies into a simple one stop shop and all the member who have posted helpful threads over the years.
STARTER
Fusible Links 101
ALTERNATOR
GLOW PLUG SYSTEM
GP Module Operation
GP Relay Repair
HEADLIGHTS
HORN
ELECTRICAL
Fusible Links 101
Soldering wires
Blower Motor
INSTRUMENT CLUSTER
HEATING/COOLING
FUEL SYSTEM
TRANSMISSION
700r4 swap
The One Stop 700R4 Swap M1009
Overview Please give many thanks to the 10+ SS members for giving me the motivation to create this thread. Chuckg, 4sdair, forest522, computer54, dezertdemond, Dsilverline, Chevymike, ssdvc, TheMod, Mullaney, royalflush55, 1love, Sharecropper… By popular demand! This is a REAL M1009 1984...
MISC
Insurance
M1010 Threads
M1010 Belt Numbers
M1010 Duvac Removal
