cucv injector socket source
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
I bought an Inpact socket and put a bolt in the ratchet hole and and chuck it up in drill press and used 36grit flap wheel in my angle grinder and thrned on the Drill press and turn down the socket so it fit over the injector.
$18.00 socket. Or $40ish to 60ish.
I take a photo of and post it soon.
I had to do this because I loan my socket and IP timing ajustment bar out and they never returned back to me.
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
Yes it is and it finish is smooth because it is Black Cadmium coating.
just some tools have differnt finish and if you left out it will rust.
I bought this one from Carquest.
ODdave
lansing michigan
Dave, I should have an extra one of the CORRECT sockets. if you need gimmie a call.
Or if it helps its KM tool # J29873
K9Vic
Fort Worth, TX
thanks you all for answering the unasked question, what one works better..
Unasked question?
This has been asked many times before and I have posted a link to this place one time before over the NAPA one. I have used this many times to remove all injectors on multiple trucks and never had a problem with it. In a pinch at first I used a deep 30mm socket, but you have to be careful that you do not crimp or snap a return line fitting.
SSDiesel Supply :: GM 6.5 TD Specialists
http://www.steelsoldiers.com/cucv/66749-just-removed-my-ip-now-i-need-help.html#post798973
Jersey4x4
Absecon, NJ
I have a new in the box OTC injector socket for the short or long injectors used on the 6.2 or 6.5 engines. I am going to sell it on eBay. I bought one and forgot I already had one so now I have 2.
southdave
ripley, oh/TDY Lordstown,Oh
I might hit you for up for it, Btw some droped off a DB2831 ????? 6.5 ip today they where get rid of their chevy crap. it rebuilt in 2001 it's been on the shelf
this 30cc pump soooooooooooo..
