Cucv key blank
OK, Guys ive been searching the forum on keys and know its the B blank but also hear it can be the J blank which is a square key. Can anyone with a square key look at the key to see if theres a j stamped in it!
twright
Rockmart Ga. 30153
Do a search for cucv keys the blank code and the number to make them is on here at less a hunder times . And if that does not work for you pm me and I will send you one. unless some one has changed the locks they are all the same.
AEC Retired Wright
juanprado
2,885
Metairie/La (N'awlins)
Vendor on E-&8% sells universal military one.
I looked at buying a key as I was bidding on some close to me but lost. It appears all gm in that series were keyed a like?
1,176
B46, B47, and B48 are square.
B49(correct blank for CUCV) is round.
They are not interchangeable.
Tony thank you for the key offer!I may have not wooded my thoughs right. I have a few round keys but have seen square keys that was told they work,which are a J code. Which stamped on the shaft. I switched the door locks and now have two round keys which is a pita. Would like to know if there is a J code key blank that works or do I have to get the different colored rubber tops for them. Thanks
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
My GA Rally T-shirt that has a big CUCV key on the back side with the key code printed on it it is----Round! Hope that helps. Sure there's 50-60 participants on here that can confirm this from a few years ago.:beer:
If you're trying to get rid of 2 round keys just change the ignition to another switch, it will be square and others won't be able to start it.
UPDATE! Well after a ton of searching and visit to locksmiths the J code square key matchs as a blank for the cucv!So if you changed you door locks and are tired of having two round keys this is the fix! And you can get at lowes or home depot with the rubber head! enjoy!
Tim
1,176
Is it a B46-J key blank?
1,176
I guess I'll get one made and try it. I did not think they are identical, but will work in either(maybe?).
Does it feel correct?(when inserted)?
Doghead, It works great and also tried in old door locks ,good as well! One thing is the electronic key cutters seem to cut a better key then the old school machine. I used the axxess system keys, their blank is a 7r which is the b46 j blank. If you go to lowes ,you know the cut is only as good as the employee! With your help I checked the b46. Thanks!:razz:
