CUCV M1010 Radio Tray
1,808
The radio tray straddles the bent transfer case shifter. Would be decent for adding an under dash A/C.
C15TA
Castleton ON
I thought I would just make one but a buddy found one for me for $40.00. Boy it's a heavy sucker and wouldn't be that
easy to duplicate.
Barry
wardog5428
medicine Hat, Alberta
it would mount between the bent transfer case shifter i have one photo that can with the cd on the truck but i can't figure out how to upload photos to here. by the look of it it had some civvie mounting brackets attached to it at a later date
1,808
If you need pics I can likely oblige. I have one out in the shed with. 50,000 other odd parts.
Drunkle Scuzzy
San Francisco, CA
I have one on my truck that I may remove and switch to a straight shifter on the t case. I noticed this is an older thread but just in case pm me if you still need one.
jpg
15
Boston, MA
Do you still have the tray, if so are you interested in selling it
I have this one available. It mounts on the forward part of the passenger footwell, using 4 philips screws set into rivnuts there. The cable passes through the firewall and connects to the battery buss bars. I've been told it was for NBC detection gear, and for radio gear. It's heavy steel construction.
Fair warning. The radio rack that mounts over the transfer shift lever sticks way out into the passenger's footwell. My 5'10" son couldn't stand it protruding into his space on long drives. It dug into his leg. The footwell rack bothered him far less.
MuleMac01
Military vehicle collector
158
Las Vegas Nevada
Found this on a topic on the web site I'mCUCVRadioShelf.jpg going to make one later for my M1028A1 to put a radio in the cab. maybe you can do the same?
tourus
madison me.
If someone with a radio rack out of the truck could take up close and detailed pictures and then some good measurements any good metal fab. shop could build a person on if they wanted one.. The shop I go to when I need something made loves to see new and adventurous things like that..
