cucvrus
- 10,427
- 113
- Jonestown Pennsylvania
I have a customer that is dropping off his M1008. He wants NAPA oil cooler lines put on it. He sent me the cooler lines and will be dropping the truck off. he had called me and ask me if I would do the job his were leaking. I said yes I could replace them. Do the Balkamp NAPA lines fit. I have been replacing the hoses and clamping the lines to the OEM barbed aluminum ends. this guy sent me new ones so I will put them on. I would like them to fit the engine the bracket at the engine and be correct in fit and function. Just asking. I am going to needing a set for the Easter Find M1008 and wanted to ask for positive or negative results from the use of these lines. Are the AC Delco ones still available. The GM dealer says NO. I see some on Amazon but they appear to be the same as these NAPA Balkamp ones. Which I suspect are China made. No problem if they fit and do the job.
