CUCV questions?
williedawg
Wilmington, NC
I have a 1985 M1009. I plan to put a new dash cover on in the near future. While I have the dash cover off, I want to inspect and clean the connections and wiring for the dash and I will also be replacing the radiator core. Just because I will already be in the dash, kill 2 birds with one stone. My radio does not work. Is that because it was never hooked up to work, since it was military vehicle, or is it screwed up? It's the old 2-post style radio.
Once I get back home, I work overseas, I will post pictures of my truck and update my profile. Any and all suggestions are welcome. Thank you.
Brian "Williedawg"
319
Lieutenant
58
Michigan
Radios were not installed at the factory. It's a good idea to inspect, and clean if necessary, these connections, especially the instrument cluster and printed circuit. Be sure to pay attention to all grounds, as they can cause a lot of issues in these older trucks.
Good luck.
MarcusOReallyus
815
Virginia
No telling why it doesn't work. It's not stock, that's for sure. Do you see any speakers mounted anywhere? Anyway, since it's not stock, you might want to take this opportunity to replace it with something newer. It's not like you'd be spoiling a historical radio.
