CUCV Restoration recommendations
gskwared
New Windsor, MD
I can upload pics later. I have 2 M1028’s both are 1985 models. One has a good clean frame and the other has a mostly clean cab with minimal rust on the cab corners only. The truck with the good frame has clean tenders that the fire department cut holes in to put lights. The other has a good passenger side fender but the drivers side has scoring from what looks like a previous owner tried to take the carc off with a wire wheel and gouged the metal.
cucvrus
10,427
Jonestown Pennsylvania
Anything is possible. I have lots of replacement sheet metal. I retain every original GM sheet metal part I get my hands on. I bought vehicles just for the nuts, bolts and good sheet metal. Military and civilian the sheet metal and 98% of the parts are the same. I would be interested in seeing pictures before I could elaborate further. Are you talking everything gone over? Driveline, suspension, everything. That get in-depth. I have been there many times and am currently involved in 3 M1009's. I will look if you will show. Thank you.
firefox
General
51
Berkeley CA
CUCVRUS's track record speaks for itself. If you can get him to do it, it will be money well spent.
