corelokt
- 2
- 16
- Duffield, VA. (East of nowhere).
Well, found a burnt out fuse link from under the junction on the firewall. Replaced it and the others there that were not the two really heavy red wires with breakers and a fuse box. I also removed the link to the junction box and plumbed in a pair of 50amp breakers in parallel. Everything worked great, then didn't. When it started, it did so much better than its usual, as in it really cranked over great. It ran a half minute then shut down. Now it will crank once then be dead again for awhile. All the leads I changed still have power when it is dead. Is there something inside the cab that will do this, or something under the hood I am missing?
