- 249
- 255
- 63
- Grove, Oklahoma
Hello All... While working on my transmission, I noticed a great deal of transmission fluid on the underside of the truck body where the drive shaft enters the model 208 transfer case. I realized that this is probably due to a failed rear transfer case seal so I replaced it (Item # MPS 9449, $4.94 - O'Reilly auto) and then decided to replace the ATF within the transfer case. I know I need a 30mm socket to remove the drain/fill plugs. Once the transfer case is empty, do you use a thread compound on the drain/fill plugs before you reinstall? I usually use the Blue Monster Tape when working with plumbing components so I have that available. Thoughts anyone???
