cucv trouble
treeclimber1971
willington ct.
Hi I have a 1984 cucv. I was driving home with it and I seemed to be loseing power but I was able to go a few more miles.
I reached a hill and I was done truck would not climb the hill. next day I changed fuel filter, it started fine and ran good for about 10 minutes. I had it towed home and tried later to start it. It was running really rough and lots of smoke (blue). and no throttle at all.
I could really use some advice. I was thinking lift pump or IP? Is there a sure way to find out? Also is the IP 12 or 24 volt?
Thank you for any help
270
akron, ohio
I agree with Recovry. I had a similar situation with my M1010 a couple years ago and it turned out that I had gotten fuel with a bunch of water in it. My smoke was mostly white, but the other symptoms were the same.
408
Colo.
Same thing happened to me when failed to keep the tank full on a very cold spell (-F's). Blue smoke as well. Filled the tank with some winter diesel, added some antigel, changed the fuel filter and it cleared right up.
