pl1338
- 0
- 1
- Capital City of ohio
Hi, new member here. I have a 84 M1008 truck that I bought earlier this year. It has run like a champ the little bit I've actually driven it, I took it for a spin the other day and the ignition took a good bit of messing with to get the thing to shut off! Well, I shut er down and went to bed, the next day, batteries are dead? Won't start! I get those charged, and start it up... This time it would not shut down, as a last ditch effort I found a fuse under the dash marked Engine control or something similar, when I pulled it, the engine immediately shut down. Hopefully, I didn't cause any damage to anything. I did have both alternators tested at an electric motor shop, he said both were perfect, so why would those batteries have drained out? (And no, I did not leave the lights on, just in case you were thinking it) It has sat for a couple months and had no problem starting up after that, but over night after a half hour of driving with the lights on, it's dead the next day? I have been getting the GEN1 light flickering under idle, but not really under load.
Anyhow, I am going to pull the steering wheel and see if the ignition switch is gonna be a half easy job or a total nightmare. So, my question is this, Has anyone ever changed out a ignition switch, and is it super difficult? Also, the dead batteries, any ideas on those? The truck has run great since I brought it home... Any help is appreciated.
