70deuce
- 121
- 43
- Franktown, CO
While pulling the 2 rear injectors to swap with the 2 front injectors to trace "cold cylinders" (the 2 rear are running way cooler than the other 4 as measured with an IR thermometer), the number 2 injector plunger decided to fall out on me and drop through the rocker box, pinball around down by the cam and drop into the oil pan. Hate when that happens!!. You get to practice changing the oil AND removing and replacing the oil pan. The little bugger landed in the large flat tray forward of the sump section of the pan so there was no chance of fishing it out with any magic wand. Thankfully it went all the way through to the oil pan. Afeter the practice on the oil pan and some $$$$ for 24 quarts of oil I did isolate my cold cylinder problems to the injectors. 1 and 2 and now the cold cylinders so I will be pulling all 6 for rebuild. Oh yeh, you get to practice adjusting the valves and injetors when you need to swap or pull injectors. Just wanted to tell everyone to watch out on dropping anything through the rocker box. There are fairly large openings where all kinds of things can go to the wrong place. Photos included are the culprit plunger and the rocker box that sucked the thing in.
