Cummins 250 parts manual in the TM section
area52
San Bernardino CA
The tech manual in the TM section thats for the Cummins 250 says its for the 939 series trucks.
Is there any differences between this one and the one in the 809 series?
Is there a different tech manual for the 250 in the 809 series?
thanks
papercu
31
Baxley, Ga.
The M939 and M939A1 series vehicles employ the Cummins (NHC 250) 250 horsepowered engine, while the M939A2 series vehicles use a smaller, turbocharged Cummins (6CTA8.3) 240 horsepowered engine. Wayne
WillWagner
2,707
Monrovia, Ca.
I also have the one for the 800 series trucks, but they are identical, figured just the one would work. If you like, I can scan and submit the other one.
wreckerman893
Possum Connoisseur
15,628
2,042
Whiile we're on the subject of the 250 Cummins...how do you install the belt that goes from the big pulley to the water pump.......no way to adjust or get the pulleys closer together to slip the belt on...this is making me :cookoo: aua
I took the pulley off the water pump using a pulley remover but cant get the thing to go back on with the belt on it...Please tell me I don't have to take the big pulley off.
wreckerman893
Possum Connoisseur
15,628
2,042
I don't have the TM yet...the engine is out of the truck and it is a lot easier to do all this now before we drop it back in.
Maybe I can download it if I can find the info ( I am old and puter deficient)
WillWagner
2,707
Monrovia, Ca.
RE: belt
Wrecker, get e new copper gasket for the pump mount and coat it with never sieze. It will make future adjustments easier. Tighten the bolts evenly so the clamp ring doesn't break. Use the torques in the book.
jasonjc
289
Gravette Ar.
RE: belt
Check the water pump. Mine had a plastic impeler that was cracked. It will be a hole lot easyer to replace now than later.
Gamagoat1
44
Kiowa, Colorado
Re: RE: Cummins 250 parts manual in the TM section
Will,
Which manual are you refering to for the 800 series 250
WillWagner
2,707
Monrovia, Ca.
RE: Re: RE: Cummins 250 parts manual in the TM section
Yup. I compared both manuals, they had the samp P/Ns on the things like intake and exh, manifolds and the bolt on externals.
