Cummins 400 B.C. MPG?
290smallcam
36
peru,indiana
Quick question. Looking at putting a 400 in my M 813. Those of you that are running them what MPG are you getting? Or should I just stay with my turbo NHC 250?? That gets around 8-9 MPG empty with 16:00R20's.
simp5782
Feo, Fuerte y Formal
9,369
Mason, TN
In a 5 ton
Around 8 to 9 with a .83 OD in the 16 speed on 1600s. It also weighed 27,000lbs.
7mpg with an empty 13,000lb M322 trailer in tow
5 to 5.5 with a loaded trailer. 60,000lb and heavier
In a 915A1 with 12R24.5s
Empty at 23,000lbs. Direct drive 9mpg.
Empty 870 lowboy at 45k 6.5mpg
Loaded 4.5 to 5.5
920 empty at 58mph 7mpg. This is with aneroid and HT4B turbo.
All of my engines have 250 rail pressure. #5 or #10 buttons and no aneroids so I lose fuel thru thru rolling coal. I also rub 220cc injectors and larger HT4B turbos on the 923 and 915
290smallcam
36
peru,indiana
Ok so no real gains. Was hopping in the 12's but didn't think 9mpg! Was thinking of removing the fan and the fan spacer, to move the radiator back. Installing electric fan and adding an air to air after cooler. That might get me more MPG? All that's done to the motor is, add S.C. 290 cam and timing. Plus HT3B turbo. I'm not looking for jobs of HP, but more MPG.
simp5782
9,369
Mason, TN
Add a pressure gauge so you can tell where your throttle is when driving. Especially cruising it will show you where you may be running 50psi down the road. You can maintain the same speed by running 30psi with just letting off your foot a tad.
