Cummins 7.5 HDKAT/41934 Generator
M1Kodiak
Kodiak Alaska
So I went to recover a M1101 trailer that I won, and in the back was a Cummins 7.5 HDKAT/41934 diesel generator! The GL guy came over and asked if I had any goodies in the back and said it was part of the lot. Lucky me! It has a flat dark earth paint scheme on it and was in several pieces in the trailer, so I am not even sure it works or if all of the pieces are there. The funny thing is I even went to preview all of the trailers and looked inside of them all, but this one trailer was in a different part of the lot.
From what I've found, it is 7.5kw, close to $8000 new. Is the military moving to these types of generators rather than MEP's, or is this classified as some other type of MEP generator?
I didn't have a chance to get any good pictures since it was dark, but I will take some so this thread is no longer worthless.
M1Kodiak
Kodiak Alaska
Anyway, It has 6127 hours and looks pretty beat up. There is a note with it saying that "the engine is worn out, excessive crank case pressure, low oil pressure. Recommend replacement."
Isaac-1
50
SW, Louisiana
The military does operate lots of civilian generators, particularly in non combat standby generator operation, they also seem to tend to change them out all the time. I know when I go to pick stuff up from GL at Ft Polk, near here I have to drive by at least half a dozen between the front gate and the DRMO site, and that is going the back way across the base that avoids all but 2 traffic lights. Going the suggested simpler, but longer route, passing by HQ and I would likely see 15-20. In fact there are 3 within site of the front gate complex, a 30 KW with base tank sitting behind the guard shack, another somewhat larger (50 or 60 KW) by the side of the visitor pass building, and a 3rd at the welcome center just inside the gate. I also know that the one behind the guard shack has been changed out at least 3 times in the last 5 or 6 years as the brand name on the housing keeps changing.
Ike
p.s. with the prices on Kubota engine parts you might be best off parting this one out
