Cummins cooling fan
jayjaytocool
rochester ny
Okay so the cooling fan on my m923 with the cummins comes on as soon as air get over 30 psi. I have nailed it down to the air valve on the coolant cross over pipe. How ever I can't seem to find a replacement any ware I think I must not be using the right terminology in my searches. does anyone know what this thing is called or where I might get a new one. P.s. I did have it apart worked for a while and now same shat.
jayjaytocool
rochester ny
If it matters its an a2 so it has the 8.3l. Please help I'm going to use it this winter for hauling sap. Just installed swing fire cold weather kit. That thing is freakin awesome. But with the fan running It might be a tit bit nipply in the cab.
Floridianson
2,498
Interlachen Fl.
Shutter stat. try google and if not I just got one for my 920 so I might find the web sight again . Also google bendex clutch fans and there parts.
I google and I think it was www.fanclutch.com. try and call and tell them what you got.
I think you need the one that is normaly closed and opens when it hits the temp you need.
What is the number on yours 190*
Jones
Sacramento, California
This is for the M939s but it should get you in the ball park;
Actuator, Fan Clutch - NSN 2930012855027 - cage code 21102 - EVANS TEMPCON INC. 616-447-2838 - P/N CA 200011
