Cummins NH250
jeepcato
13
norway
Hi, Does anyone know about a repair manual for this engine ? I need to replace 1 sylinder kit and 2 injectors...... i have the parts but need installation instructions an torques etc......
this engine is in my M-929 A1 dump truck
M35A2-AZ
389
Tonopah, AZ
I just rebuilt a NHC250 and have all the torques valves, if you let me know what you need I can send them to you. A repair manual is very hard to find, may try Ebay.
jeepcato
13
norway
Hello,
well i am replacing 1 cylinder liner kit.... new piston, so i need the torque for the cylinder heads and for the piston rod....... i also need instructions for valve and injectors clearence as im replacing 2 injectors
Guyfang
23,347
Burgkunstadt, Germany
These two links might help you a lot. Look in the Forum TM Forum.
M35A2-AZ
389
Tonopah, AZ
Here is what I have and used on my rebuild.
Oil Pan bolts 40 lb-ft
Intake 30 lb-ft
exhaust bolts 25 lb-ft
Rocker box covers 15 lb-ft
Rocker box bolts 65 lb-ft
Head blots 25 then 100 then 200 then 305 lb-ft
Rod bolts 75 then 150 loosen then 30 then 75 then 150 lb-ft
Crankshaft Main 140 then 300 Loosen then 140 then 300 lb-ft
Valve nuts 45 lb-ft
Injector 70 lb-in
