area52
- 5
- 38
- San Bernardino CA
Well, I finally got my fuel lines and other stuff fixed on the M816 wrecker and fired her up for the first time. Cranked a few times and VROOOM!! Idled at about 650 rpm, oil pressure came up to about 30-40 psi. Checked for fuel leaks and it looked good. Noticed air pressure was not coming up so I gave it a little throttle. It seemed very slow to come back to idle but it did eventually(maybe 15 seconds??)
Still no air increase so I gave it a little more throttle and let off- all of a sudden it shot way up in RPM so I jumped out and shut off the fuel shut off valve since I didn't have the cable hooked up and the electric was turned in. NOTHING!! It was still reving very high and I thought it was a run way so I started stuffing the air cleaner inlet and my brother in law who was helping me turned the fuel tank selector switch to the other tank which was empty and it finally died.
So my question is - how long does it take for the engine to die after you close the emergency fuel shut off valve?
I checked the throttle cable and it was all the way closed.
Any hints or things I should check before attempting another start?
thanks
thanks
