Cummins NTC 400 Oil Plug Size
fuzzytoaster
3,671
Fort Worth, Texas
Needing to know the size/thread/etc of the oil plug for an Cummins 400 BigCam II. The TM's have the instructions for re-threading to larger plugs but no size of the standard plug. I can hope it shares the same pan with the Cummins 250 but that is a guess at best. Thanks in advance.
fuzzytoaster
3,671
Fort Worth, Texas
Manufacturer/Proponent:CUMMINS INC.
Nomenclature:PLUG,MACHINE THREAD
FSG (Federal Supply Group):53 (Hardware and Abrasives)
FSC (Federal Supply Code):5365 (Rings Shims and Spacers)Part Number: 69962 <-------
MRCCriteriaCharacteristic
MATTMATERIALSTEEL COMP 12L14 OVERALL
STYLSTYLE DESIGNATORE16 PLUG, MAGNETIC
AASUHEAD HEIGHT0.310 INCHES NOMINAL
ADAQBODY LENGTH0.400 INCHES NOMINAL
AJFVMAGNET PROJECTION LENGTH0.180 INCHES NOMINAL
AHNCCONNECTION STYLEJ1 PLAIN
THSDTHREAD SERIES DESIGNATORUNS EXTERNAL
CQJXNOMINAL THREAD SIZE1.000 INCHES EXTERNAL
CMLPTHREAD QUANTITY PER INCH18 EXTERNAL
AAJDTHREAD CLASS2A EXTERNAL
AAJFTHREAD DIRECTIONRIGHT-HAND EXTERNAL
AASATHREAD LENGTH0.260 INCHES MINIMUM AND 0.275 INCHES MAXIMUM EXTERNAL
FEATSPECIAL FEATURESMATERIAL ALSO CONTAINS TELLURIUM
