Cummins PT pump questions
TimG102
Wellsville, Ohio
I'm new to these trucks and I'm trying to understand if there is any difference in the PT pumps. I'm working on starting an M818 with a NHC250 that has sat for many years. Went thru all the normal stuff. Checked all the fluids, new batteries, drained tank and new fuel. Would not crank, found it was a bad protective control box. Once I got it to fire, it would rev high and I would use the shut off fuel lever to kill it. Throttle linkage seems to move freely. Maybe a stuck governor? Looking at the manuals I'm seeing AFC, VS, MVS...I would like to buy a rebuild gasket set. What type of pump do I have and who has rebuild kits.
