Cummins tear down
M215
Spotsylvania, Virginia
Hello SS,
Pulled the heads off the NHC250 this weekend, everything on this engine is BIG!
The motor was starting to consume water and noticed / smelled antifreeze out of the exhaust. Hoping it was just a cylinder head gasket or a cracked head. I really did not want to pull a cylinder liner, looks like I may have no chose.
Picture shows leak / stain below #4 cylinder exhaust port. Head gasket between #3 & #4 was rusted, maybe that was the problem. Cylinder of #4 is pitted with lots of lines and sratches.
As always, time and money.
jwaller
19
Columbia, SC
I would defiantly have all the heads surfaced and pressure tested before I reinstalled them. might also be a good time to have the injectors cleaned and tested.
also be a good time to install a block heater and coolant filter.
