So this was my problem, its dark back there:
I'd prefer if it looked like this:
Some more photos of the install:
Black box contains:
2 sealed batteries (12 VDC 24 Ah each)
120 VAC charger for batteries
120 VAC input to inverter board for bypass mode to 120 VAC output
The 120 VAC has a switched output (turns lights on/off)
Has an inverter board to take the 24 VDC from the batteries and create 120 VAC when primary input 120 VAC in not available
The LEDs are driven from a driver board that takes 120 VAC (about 20 mA @ 120 VAC) in and ~80 VDC out to the LED arrays (total of 8 driver boards)
The driver boards are located in some extra space inside the black box
Box is mounted on vibration/shock mounts to keep it safe
Ran all the wiring neatly with wireloom and I think it came out great! Should run 40+ hours on battery. Great for camping hopefully.
Black box contains:
